Hey guys
Just brought this card from OC
http://www.overclockers.co.uk/showproduct.php?prodid=GX-078-OK&groupid=701&catid=56&subcat=416
Now in the Catalyst control center under Information center -- Graphics hardware it tells u all about the card this is what mine says
Graphics Card Manufacturer Powered by ATI
Graphics Chipset ATI Radeon HD 3870
Device ID 9501
Vendor 1002
Subsystem ID 0000
Subsystem Vendor ID 0000
Bus Type PCI Express 2.0
Current Bus Setting PCI Express 2.0 x16
BIOS Version 010.072.000.001
BIOS Part Number RV670 DDR4
BIOS Date 2007/12/20
Memory Size 1024 MB
Memory Type HyperMemory
Core Clock in MHz 775 MHz
Memory Clock in MHz 1125 MHz
Primary Display Yes
Im just a bit confused about the memory clock in mhz as it says on the oc web site thats it has 2250mhz and not 1125 ?
Plus the other thing i noticed was it states its 1024mb and not 512 mb ?
So was just wondering if anyone else has noticed the same problem but not sure of its a problem atm tho
And its not over clocked or under clocked or anything just install straight from the box with 8.1 cats.
Thanks all..
Device ID 9501
Vendor 1002
Subsystem ID 0000
Memory Size 1024 MB
Primary Display Yes
Thanks all..
