Question about the GTX260
7 Apr 2009
Gah, I'm killing myself by constantly upping my budget on my new build, initially a £300 'quick fix' is now turning into 5 or 600 pounds.
Anyway, about the GTX260, I have two basic questions.
Firstly, what powersupply level should I be looking at?Is a 500W pushing it, or is a 600 more realistic?
I'm not a huge fan of buying expensive cases, and was wondering if the coolermaster 335 or 333 or 330 would accomodate a card that I heard is fairly large?
Thanks in advance guys :)
If its a good quality 500 it should be ok, I had no problem running 260GTX SLI on a 600 (tho I upgraded to 700 to be sure (and it matched the color scheme I was going for better :D)).
I have the coolermaster 330 and it is a good buget case but you need a second 120 mm fan for the front in take. Some models come with a coolermaster PSU 570W (not sure about the watts but i believe is over 500W) which is good enough for the GTX260
