Question about Vrm block x58/2011
I'm sorry If you feel it didn't help, the site linked shows every EK block that will fit on that motherboard.
If they don't list the model number of the block you wish to attach, then I'm afraid it won't fit
Right, Sry, Felt bad about the bluntness of my answer.
The "EK-MOSFET ASUS X58 KIT"
Will not fit on the Rampage 4 extreme, This is due to the placement of the other mosfet but primarily the length.
"EK-MOSFET ASUS X58 KIT" Length: 95.22mm & 84.13mm
Rampage 4 Mosfet length: 106.93mm
