question about what direction i should go.
Permabanned
7 Dec 2005
Ok after i graduated worked in a bank as a trainee trader got the boot after 9/11 then worked in IT support on and off, i havent worked in support for 5 months now, reason i like IT stuff but cant stand users.
1) Is it worth it taking the mcsa exams?
2)Also iam looking to start a masters in management 2 years.
I just dont know what i want to do? just need advice i want to progress but contracting doesnt lead to a higher job level.
Mohinder said:
Left! No right! No left!
Unfortunately Mohinder is right - Life is just that! Do you have any idea what you want to do as this would help you with your decision significantly. Personally I want to pay off what I need to, and start over again. I'm learning the hard way :)
