Question about Z-5400 speakers
if its the same as the Z-5500 then it will have a COAX digital and an OPTICAL digital and then surround sound analogue in . because its the older model it wont have more than what i just said, probally less, but make sure you know the 2 digital inputs are different (COAX/DIGITAL)
i have my xbox 360 through optical
i have my Audigy 2 platinum through Coax
and headset in the 5.1 analogue (5.1 headset)
hope this helps
I just had a look on the logitech website and it seems that the z-5400 has 2 optical digital and 1 coax digital input, with no analogue PC input.
The z-5500 has 1 optical, 1 coax and 1 analogue PC input. I really wish they made a set that had 2 optical and 1 analogue, that would be perfect for me.
