Hi peeps.
Ive just run orthos for about about half an hour with coretemp to monitor my cpu temps and during that time no error's came up or anything but coretemp reported temps around 75/71'c.
This is the main bits of my rig. E6600 C2D, 8800GTX OC, G.SKILL 6400 DDR2 RAM.
I have the cpu at stock volts.(1.35v) and ram at recommended volts as said on the ram..(2.1v).
I have an arctic freezer pro 7 on the cpu and are getting these temps running orthos overclocking the cpu to 3.2ghz from 2.4ghz..(fsb 356/357 ish x9).
The thing is what are the highest recommended temps for this cpu under an orthos stress test as im sure this is too high and have looked about but again, it seems ok with orthos after half an hour with no errors etc but high temps.
I may try reducing the fsb and see if the temps drop.
This is on an ABIT AW9D MAX MOBO.
Thanks.
p.s. this is using the Small fft's- stress cpu test.
Thanks.
