question - asus pundit p2
24 Mar 2008
Hi there,
First time DIY'er here. I had bought an Asus Pundit P2-M2A690G -- to replace an old Dell desktop mail-dns-etc. server -- in early Feb and fitted it with:
Sony NEC Optiarc AD-7200S 20x DVD-RW,
Hitachi DeskStar 7K 160GB SATA II HDD
GeIL 2GB PC2-6400C4 DDR2 memory
and AMD 64 X2 4800+.
I removed 1 of the memory sticks as it caused memtest to blow up after about 20 sec (figured this out quickly enough, after a couple evenings of random freeze-ups).
I had the system up and running for about 3 weeks when it quit on me overnight -- it wouldn't even turn on when I hit the power switch. After I read some forums (including here) I tried a couple things, like removing everything I could in the system (network card, cpu, hdd, dvdrw, mem, even the CMOS battery at some point) and then hit the power -- nothing. Then that evening the system magically booted, and stayed up for all of 5 minutes before shutting off again. I tried half an hour later and same thing.
I figured it was either the motherboard or the PSU and decided to RMA the system. The RMA page wasn't especially descriptive (no indication of any problems found) ... so hoping I was just unlucky first time and it wasn't something like putting too much equipment in there for the 200W power supply :confused:
OC are saying the RMA is closed and I'll get a new box 'current stocks allowing'. So -- anyone had experience with the P2 pundit? Anything in this story raise any red flags?
Thanks.
