- 6 Feb 2008
Got a Biostar P45 with 4870 do i need to connect the molex to the 'graphics auxiliary power' on the motherboard?
I though the molex mb connector was only for when you are using both pci-e slots? I guess it wont hurt though i have never used it.
Just checked my MB manual and it says that it has to be plugged in if only both slots are occupied by graphics cards. my gtx280 has a green light so think i'll just keep mine unplugged
