Question Corsair 7000D - Corsair HX1000i (2023) cables question
9 Feb 2024
Europe
Hello!
I bought a Corsair HX1000i power supply.
In my Corsair 7000D case, unfortunately, the ATX (24PIN) cable just reaches the socket. Is there a longer cable of the same quality as the factory one? How would you solve it?
+ question. Is there a reliable 90 degree 24 pin adapter?
Many people complain about fire damage in the case of cable extensions and adapters.
Thanks!
Corsair sell a cable (610mm), but I don't think it is much longer than the factory cable.
So long as you avoid cheap unbranded imports and go for a recognised brand like OCUK sells (Phanteks, Akasa & Silverstone), I think you'd be fine.
Unless it is for your Corsair PSU, Don't buy something that is PSU specific (i.e. plugs into the PSU ports) rather than the device-end.
