- 25 Nov 2011
- The KOP
First let me just say sorry for posting this here, I know it should be in the CPU section but I have had a topic in there for couple days now and still not had a proper answer.
I using the Overclocking Profiles on my Asrock z68 extreme4 motherboard and have my i5 2500k set to 4.6ghz.
Now I read MB profiles normally set a to much Voltage for the Overclock so I would just like one of you to tell me if this voltage is fine.
Idle is 0.976v
Load is 1.391v
Temps Idle 35c
Load 64c
I know my temps are fine I just dont know much about the cpu voltage when using profiles is this to high?
Thanks
Idle is 0.976v
Load is 1.391v
Temps Idle 35c
Load 64c
Thanks
