Question for antec 900 owners
Tip
Tip
13 Aug 2008
Hiya all, i have been building my new pc this evening and wanted your opinion on something.
The case has 2 drive cages which each hold 3 hard drives.
Now i am using 3 drives in this machine but one of the cages can have an additional fan attached to the back to aid air flow.
What i would like to know is would i be better off putting the 3 drives in the one cage and using the other cage for the additional fan on the back ( you cant fit it with drives in the cage ), of would it be better for me to space the drives out more over the 6 slots ( 1 drive per 2 slots ) and leave the additional fan off??
many thanks
ricky
the extra fan wont make that much difference, better to spread the drives out so the front fans cool them better.
My thoughts exactly. Really is no point in it. The fans still provide good enough airflow with the drive split up. :)
many thanks
ricky
I stick them all in the one cage
I think i may try and split them up then as i have a tuniq tower so the side far wont fit.
i just wanted something else to control off my fan controller, LOL
many thanks
ricky
many thanks
ricky
Sorry to bring up an old thread, but cut one of the corners off the fan. You can then put the fan on the side with a Tuniq Tower installed also :)
