Here goes.......
The bathroom (in the extension built in 2000) currently has 4x MR16 50 watt Halogen downlights (none of which are ip rated, even the one over the shower). The plan is to switch them to GU10 LED's by replacing the fittings and the one of the shower with a proper sealed, ip rated unit. Currently each MR16 has it's own individual 240-12v transformer, the 240v input is two core (no earth cable) though the wall switch is earthed and presumably the junction boxes in the loft the feed the downlights are earthed too. The plan is to snip off the 240v feed as it enters the transformer and then wire up my new GU10 fittings to the 2 core 240v feed. The IP rated light doesn't even have an earth, and says not to earth it in the instructions. The 3x non shower rated have an earth terminal but I have no earth to connect to it, as the cable on a GU10 fitting is double insulated where it passes through the fitting, does it need an earth? Plus the fitting if more of a bulb holder than a part of the light? Googling gives me differing opinions on this and makes me more confused than when I started!
Thanks in advance.
Dave
Thanks in advance.
Dave
