- 28 Mar 2004
hey all,
im editing a project at uni on avid express pro and need some advice!
basically when you look at the stuff youve edited on the pc, it looks like film quality, due to the frame rate being lower then of the output tv. On the output tv it looks like it should (filmed on dv tape) and just doesnt look as proffesional as it does on the pc screen. Question is, is there anyway to lower the frame rate in avid by only 1 or 2 frames, yet still maintain the original length of footage. I can actually get it to look film quality by putting a 1 frame strobe effect on the clip, but it extends the clip and therefor audio is of no use as the clip is running too slow. Cheers!
