6 Apr 2010 at 10:02 #1 apl1970 apl1970 Associate Joined 24 Mar 2010 Posts 9 What`s the distance (in mm) between the floor of the case and the underside of the I/O panel (USB)? I mount to remove all the drive bays and mount a triple 120 radiator behind the grills at the front. Thanks in advance.
6 Apr 2010 at 13:37 #2 apl1970 apl1970 Associate OP Joined 24 Mar 2010 Posts 9 That should read:- ` I want to remove all the drive bays and mount a triple 120 radiator behind the grills at the front.` 16 views and not 1 reply
7 Apr 2010 at 13:12 #3 apl1970 apl1970 Associate OP Joined 24 Mar 2010 Posts 9 Nobody has a CM 590 to measure for me?? I can`t even get an answer from coolermaster.
