Ok so i have a DS4 that'll be getting fitted soon, just wondering about how much airflow is needed around the heatpipe coolers to keep the chipset temps reasonable, as that'll also help me decide wether to use say Big Typhoon or a Ninja or maybe even an AC7 Pro?
It'll be oc'd and be living in a TJ06 with a 120 coming in at the front and a 120 out at the back, get good temps with the current [email protected] 100% load 48'c and thats with an old Coolermaster Hyper6 and a 80mm quiet ystech so i reckon the case cooling may be ok for an AC7 Pro.
So what are you guys using?
any suggestions welcome.
Cheers.
Cheers.
im hoping chipset coolers will be getting plenty of air anyway as the board will be upside down so cpu at the bottom of the case where the 120 blows in and another at the back going out, might even end up using the wind tunnel bit that the case came with.
