Question for glasses wearers
22 Nov 2017
Morning all
I was prescribed reading glasses in 2023, I currently have a it of time on my hands and one of the things I am contemplating is booking myself in for a new eye test as it will be approaching three years since my last test. I only need the glasses for reading and computer use but I am becoming more frustrated with being out and about and wishing I had brought my glasses for reading my phone or menus etc. Cheaprest easiest option would be to just take my reading glassses with me but I am wondering if I should consider investing in a pair of progressive glasses for general use?
Curious to know if any of you have been in a similar situation and what you think?
Thanks
Morning all
Thanks
I’ve worn progressive lenses for years. 2.0 for reading t the bottom of the lens, dropping to 1.25 in the middle for PC use and clear in the top third.
I do need my eyes retested and I don’t spend all day in front of a monitor anymore. So I’ve been using cheap 2.0 safety glasses for fixing stuff and straight smoke tint safety glasses for mowing, trimming and chopping firewood.
Thank you, and do you think it was worth moving to progressive lenses?
Just found my 2023 prescription, I have a "Sph" of +0.25 for both eytes and a "near add" of +1.00 for both eyes.
It was absolutely worth it for me as the alternative was 2 pairs of glasses or a pair of old school varifocals.
A word of warning : good progressive lenses that don’t have a bunch of distortion if you tilt your head are not cheap. Very not cheap.
Yes, I have noticed that the price and options on varifocals is significantly greater than reading glasses. I am still rather annoyed at how much my local optician charged me for my pair of reading glasses, I think I was charged £230 which seems a lot when I found out the frames retail at £29.
I tried varifocals and couldnt get on with them. I am short sighted so wear glasses all the time, but close up stuff is becoming harder, I have found however that a £1.50 pair of cheap magnifying glasses worn over my prescription glasses makes close up stuff great again. Not ideal but it will do until I decide to maybe try a proper pair of close up glasses or look into these progressive ones people are mentioning - how do they vary from varifocals?
Edit - anything under about 30cm distance is also generally better without my glasses, so I have found myself taking them off for menus etc.
I’ve worn progressive now for years. There are various grades/type and I’ve always gone for the custom which offers the widest field of view else you’ll have to exercise your neck muscles more.
Did take me a while to get used to them. The lower section is for reading, mid for computer work and the top for long distance. Even the most expensive present fuzzy/blurred around the edges so you do have to move your head around rather than your eyes but you get used it within a week or 2.
Ah, so progressive is just another name for varifocal based on that description. I tried them for about a week but I use my eyes more than my head for the movement and found myself constantly feeling off and a little queasy, so had to go back to normal vision lenses.
Non-Volatile Memory.... or 'nevermind', depending....
Could you not get a small pair of cheaper glasses to carry for occasional use?
Being cheap means you could maybe get 2 or 3 pairs, which wouldn't be amazing but still 'good enough' for sporadic use, and easily replaced if you broke them.
Yes, that's kind of what I do now but i often forget to take. them with me or don't want to take them with me.
no - you wear the (single varifocal) glasses permanently and see close/intermediate/far. ..
plus having to find a pocket to put any glasses & a phone, if that goes everywhere, you are entering handmanbag terrain.
if you do get varifocals to see really close stuff 20/30cm then making sure your eye test includes that distance is useful,
( with narrower varifocal frames I foond that for my myopia, I could look out beneath frames for close stuff as my varifocal couldn't focus well)
Isn't the point of buying a few pairs of 'off the shelf' ones is that you can stash a pair in the car, another at work and one in your day bag etc so you don't need to remember to take them anywhere?
I was quoted £720 quid by an independent optician for a pair of glasses. So I bought 6 pairs of 1.5x reading glasses from amazon for £15. 2 years later, my prescription is still the same. I just stash a pair wherever I may need them.
