If you imagine a see saw, what's the equation that I use to calculate the balance point if I add weights at different lengths along the see saw.
For example, if I add 5kg 1m from the pivot point, how much weight do I add at the other end say at 5m from the pivot to maintain the original balance?
Does the equation differ if the pivot and equal balance point is not exactly half way in the middle of the see saw?
Ta.
Ta.
