Question for Mini-ITX Z77N-Wifi users...
1 Dec 2005
Stoke on Trent
If you are using 1600Mhz ( or faster ) RAM can you actually run it at 1600Mhz or faster? If so what RAM is it you have?
Im currently running a set of these
http://www.overclockers.co.uk/showproduct.php?prodid=MY-158-GL&groupid=701&catid=8&subcat=1517
However i cant for the life of me get my system to even POST either with the XMP profile enabled or by manually setting the timings in the BIOS. It runs perfect at 1333Mhz.
I know the RAM is fine, it ran rock solid @ 1600Mhz in my old P67 board.
My wife is using that ram on the Z77N-Wifi, checked in bios and it was already running at 1600mhz without the XMP enabled, turned profile 1 on and its booted into windows without a problem.
Thanks, any chance you can do a screenshot of your settings so i can check against mine :)
Is that at 1.5v? :)
Yup its at 1.5v, here's some screenshots for you to compare:
Thought one with the timings on and system details would be handy too:
Just realised how warm her CPU runs, might have to do something about that :).
Awesome thank you :)
Well ive tried your settings and it still dosent like it.
Only thing I can see different is you have an ivybridge CPU and I have a sandy.
Thanks anyway tho :)
