Question for Nvidia users regarding power management
26 Dec 2008
Scotland
Been a while since Ive owned an Nvidia card, I was wondering about the power management capabilities of the recent generations of cards.
ATI cards (since the 3000 series) have Power Play, which downclocks the GPU/memory dynamically, depending if the card is idle, mild use or heavy use. The idea being to reduce the cooling requirement and power consumption.
As far as Ive been able to find out, the Nvidia equivalent is Powermizer.
Does anyone have experience with it, how it compares to power play and what cards support it?
My 470 at idle= gpu 50.6mhz
Mem 67.5mhz
Shaders 101mhz
Temp 30c
Fan 1124rpm (1850max)
Volts 0.8750v
All this from Gpu-z sensors. Oh and as stated above this is automatic.:)
From the responses, at least the 400 series (and im guessing later) has this feature.
This is like the Cool n Quiet tech for the AMD CPU's then.
I wouldn't bother.
Too much hassle!
Intel CPUs do a similar thing, they can reduce the multiplier on idle. It works well enough.
Its like when I have cool and quiet enabled from the bios, it throttles my speed and I can tell it is on. I do a lot of graphic design work and when Cool n Quiet is enabled Photoshop CS5 is very laggy, but when disabled, it runs very fast.
Reason I don't bother with it.
Throttles your performance!
How does it throttle your performance? :confused: It automatically adjusts its speed depending on the demand for it. In terms of GPU, as soon as you launch the game, then it will put clocks to normal. A bit like ATI and their 2d/3D clocks.
