Question for the bikers
Permabanned
12 Sep 2005
England
Can you ride a pushbike?
I was just wondering if there is anyone who cant ride a pedal bike but have no problems driving a motorbike. I assume there isnt but you never know.
Mohinder said:
I should think even if you'd never ridden a pushbike, but had ridden motorbikes, you'd be able to get on one and ride it anyway.
Why do you ask?
I wouldn't have thought that personally. Motorcycling relies heavily on the gyroscopic effects produced by the engine rotation and wheel rotation to keep you steady and upright (hence high revs is good when doing slow moving stuff on your test etc). On a push bike you dont get that until up to speeds.
Wrong. You can pedal without falling over at around 2mph.
Lol i hadnt ridden a bicylce for ages till the other day and damn i was dodgy the front was so damn light and i cudnt keep it in a straight line for first 5 mins :D :D
I rode a pushbike for years as a kid then stopped for about 5 years before I started riding motorbikes. Not really sure if there is a link between the two though.
The only link imo is just having 2 wheels and having to go round corners the same :p but a bike is waaay to heavy to have any other link with a bicycle, mabie a gas gas has more in common :p light can move it around easier
I can ride a bike, but going up hills, I find my power to weight ratio causes serious problems. :p
I hadn't ridden a push bike for years when I got back on one I found the position of the front wheel almost right under me very strange.
That was similar to when I got off the unfaired learner bike and onto my new faired machine.
The odd sensation of turning the handle bars and the front bit of the bike still going forward threw me completely!
Same. It was really strange getting back on a pushbike after so long, and after riding a motorbike. Seems lots more wobbly than I remember it :p
Same happened to me- so strange the front not moving with the bars and lights. You get used to it pretty quick though :)
