- 1 Feb 2009
does a contract sim on three have to be used with a 3g phone, or will a 2g phone work with the sim? bearing in mind it would only be for phone calls and texts
Three only have 3g networks.
It will not work.
When using a 3g phone if you have a signal its always 3g they don't operate on 2g.Are you sure about that? Surely there are 2G capabilities for more rural areas?
Is false, no network operates on 3G only because it would be extremely bad for signaling purposes and basically force three to become a city only network. A 3G phone also has radios in for 2G, you can't even buy 3G only radio chipsets.When using a 3g phone if you have a signal its always 3g they don't operate on 2g.
Again, false. Three propped up their coverage with roaming agreements, the SIM will work fine.Apparently the sim card will stop working because they only have 3g networks it means they have to pay roaming charges for you so they cut it off. (Read it in the T&C a while ago)
