- 1 Jan 2007
What are your idle temps?
Also, are you running on air or water?
Just the usual:
What are you using to get your temps. Make sure you use coretemp or realtemp or everest and quote core temp, not cpu temp. Bios readings can be wrong and so can cpu temp (in my case my cpu temp is reading at 60degs at idle with the current bios, before then it only read 30 degs)
What is airflow like through you case?
Check the application of thermal compound and make sure you use enough/not too much.
Is it mounted correctly? Cause I would have thought the Thermalight 120 Extreme would drop temps a lot over the stock cooler.
What are your load temps like?
That will do for starters.![]()
Thirdly, I applied a light coating of AS5 on both the CPU & hsf evenly.
Thanks Ben.
I think I may have gone wrong applying the thermal paste.
I have thinly covered both the processor & hsf.
I will clean & re-apply & see what happens.
