- 18 Oct 2002
- Welsh Wales
Do you run your fan @ full speed all of the time or just for benchmarking and gaming?
Can anyone post a pic of the best way to fit these?
I fitted mine outside the case. It wasn't a difficult job, just take your time. I tightened the screws up hand tight, and checked the backplate to make sure they all protruded out the same length. When it's fitted on the mobo, just be careful when you put it in your case. I actually held the heatsink to lower it in. I did get a slight bit of movement, so once I'd secured the motherboard I gently squared up the heatsink. (My temps are fine so I can't have disturbed the heatsink too much). My 8 pin motherboard molex fits just next to the heatsink so I plugged that in, before lowering the motherboard into the case. It's a damn fine heatsink, and for the size it should be
· Easy-peel instant grab tape.
· Temperature and UV resistant.
· Water resistant.
· Holds up to 50Kg per roll.
· Suitable for both, interior and exterior applications.
· Ideal for mounting hooks, signs, numbers, pictures, cable trucking etc...Stonking great CPU cooler backplates?
Is the supplied tape for the backplate any good? I heard it was pretty lame, and some people just used their own...no-more-nails tape is tempting.
Liam
the heatsink has an upside down 'flame' design if you want the air to blow from right to left. I recently had to refit mine cos i knocked it and my temps went up (thermal past must have smudged). it was a two man job to install if your not going to take the mobo out of your case. someone to hold it just above the cpu so the thermal paste doesnt smudge, and another to try and fit the four hand screws in place before the heatsink is finally lowered onto the cpu. to be honest it wasnt a fun job, i had to use a torch and cut my fingers on the fins of the heatsink to get the fiddly screws in place. just make sure you put the thermal past on the cpu cover, not the heatsink, and tighten the screws tight enough to get a nice snug fit. good luck, and ill put photos up if you want to see mine
