ever since i got a 2nd wii mote, its behaved rather odly compared to the bluetooth controllers on my PS3. Can somebody confirm if this is normal behaviour or not ?
basically only one of my controllers works as #1 controller. If i press a on the '1 controller, it flashes the blue lights for a second, then the 1st light illuminates. If i pick up the other one, the blue lights flash for a bit longer (all of them) but it never assigns it an ID
Only way i can get it to work is if pick up the #1 controller, get that assigned to #1, then go into the menu options to add controler, then the 2nd one will get assigned as #2
does the Wii normally remember which controller is which and not let you change between them ?
