Question for you cable sleevers
14 Jun 2011
Wolverhampton
Do most people when doing there own sleeving prefer to sleeve extensions for the 24 pin and PCI cables or do you just sleeve the whole cable from power supply?
I will be sleeving the whole cables anyway but just wondered how most people approached it? All I'm thinking is you might be able to get a better bend using a 24 pin extension so may look better?
I've got an 860w Seasonic platinum btw.
I think most people who sleeve tend to sleeve the entire cable and not do extensions.
Is generally a log tidier as doing extensions makes a LOT of extra clutter to clear up behind your mobo tray
Thanks!
I plan on sleeving them all but might do a 24 pin extension separate, 1 to practise and 2 to get a nice tight neat bend from the board to behind the case!
