Question for z97 s-oc force owners using the ek full block
11 Mar 2014
hi guys. my first post for a while as ive not been well. im finely getting round to upgrading my fx8350 and i really cant afford x99. i think ive settled on the z97 s-oc force and 4790k.
my question is the ek south bridge block prevents the use of the 2nd pcie slot, but the inlet/outlet line up with the gap between slots 2 and 3. is it possible to use slot 3 for a 2nd gpu or is the sb to tall? with gtx770 so cheap i want to sli while i still can and get the xspc block for it.
last 2 pictures on the product page show what i mean:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-660-EK
many thanks in advance for any help. cheers, damien.
also is it possible to just sli using slots 1 and 4 and use the long ek bridge?
Hi.
For SLI you have to use 1+2 as these operate at 8X each. Which is the minimum you need to run SLI.
The 3+4th slots run at 4X each.
The 3rd slot also steals bandwidth from the 2nd slot when used, so you get 8X/4X/4X for crossfire or you get 8X/4X/4X/4X for 4 way crossfire if you use all the slots.
The 4th slot is actually run from the chipset and does not steal anything from the first three slots.
Crossfire works at a minimum of 4X.
ok awesome thanks stulid. im going to slightly adjust my hardware choice and go for the maximus 7 ranger instead and it only has the mosfet block. i will save money on the mobo and block then as i wouldnt be able to use the block for the sb.
looks like union jack colour scheme it is then :D.
cheers, damien.
Watercooling the motherboard these days is just a waste of time. My chipset cooler barely gets warm and my vrm's are usually in the mid/high 30's.
its because ive had bad experience with my current pc throttling due to overheating vrms (the one in my sig). i know its an amd etc but i just want to be sure and for £35 plus 2 fittings it isnt breaking the bank.
so would you say s-oc force au naturelle with stock heatsinks and 4790k? ive just picked up a b grade xspc gtx770 block from clearance section for £25. :). rest will be ordered next month.
