Question on 0CCT
16 Nov 2008
West Midlands
When the program runs it makes a duck noise and shows me graphs does that mean its unstable?
Comes up with crash code error 1.
What sec is your pc, I assume you are testing your o/c, sounds like an unstable o/c try up the voltage or drop the overclock.
Ive put the volts back to 1.7 i had it much higher.
My spec is dual core e2200 2.2 4 gig ddr 2 ram 800mhz
Geforce 8800GT
Yea im on xp mate.
