- 12 Nov 2018
I have a bequiet straight power 11.
I received a 3080 FE with an adapter/splitter. Given the configuration of the Straight Power 11, it means using 2x12pins output (PSU side, for some other PSUs like EVGA is 2x8pins I believe but for bequiet there are only 12pins output) onto the adapater that turns it into a single 12 pin GPU side.
Seems a lot of hassle but it works.
In the meantime I have emailed bequiet to get a new 12 connector for the 3080. The connector they sent is 12 pin on GPU side and 12 pin on PSU side(!). Shouldn't it be 2x12 pin on PSU side? Don't I risk underpowering the GPU if I use this connector?
I have tried contacting bequiet but did not get a response.
