Question on CPU types and if I can upgrade
29 Mar 2010
Hi folks
I have a DELL Inspiron 5348 All-in-One PC which appears to have a knackered motherboard. It comes with a i5-4460S. My PC has a i5 2500K in a Asus P8Z68-V (rest of system spec in my forum signature).
What I am wondering is, would the CPU in the Dell fit my machine, and if so, would it be a reasonable upgrade, and worth the hassle of removing from the Dell, and putting in my machine?
Different CPU series tend to need a different motherboard especially where Intel is concerned.
Your 2500K is likely the better CPU, as it can be easily overclocked, if you don't include energy saving as a metric in your calculations.
