Question on fan control/power cables
10 Nov 2015
HI,
I am presently in the process of finishing off my new build (pics will be on soon hopefully) but I have hit a snag.
The Phanteks Luxe has a PWM which is meant to connect by 4pin to the mobo cpu fan header. However, I am also using a H110i which has a 3 pin that is meant to go onto the mobo fan header as well.
Should I connect the H110i direct to the mobo and use the cpu.opt header for the pwm, or should I connect the pwm to the main cpu.fan header and the H110i to the pwm?
Any advice will be gratefully recieved!
The PWM fan hub is designed to vary the voltage to attached devices so make sure the pump is meant to have a variable input voltage before attaching to that.
Typically you'll want the PWM fan hub (or your CPU FAN) attached the CPU_FAN header and other stuff on the other headers.
