- 1 Jan 2007
I am in a predicament as to which GeForce GTX8800 card to use as there are so many different varients. The one which have caught my eye are (Most expensive first): -
768MB BFG Technology 8800GTX Water Cooled PCI-E(x16) Mem 2000MHz GPU 650MHz 128Streams HDTV/2xDVI-I
768Mb XFX 8800GTX XXX, PCI-E (x16), Mem 2000 MHz, GPU 630 MHz, Dual DVI/HDTV
768MB EVGA 8800GTX KO Superclocked PCI-E 2000MHz GPU 626MHz 128Streams Dual DVI-I/HDTV ACS3 Arctic C
768Mb XFX 8800GTX, Extreme, PCI-E (x16), Mem 1900 MHz, GPU 600 MHz, 128 Stream, 2x DVI/HDTV
768Mb EVGA 8800GTX PCI-E (x16), Mem 1800 MHz, GPU 575 MHz, 128 Streams, 2 x Dual Link DVI-I HDTV
768Mb Asus 8800GTX PCI-E (x16), Mem 1800 MHz, GPU 575 MHz, 128 Streams, 2 x Dual Link DVI-I HDTV
It is obvious that the differences between each model is the speed but will there be considerable performance differences between the BFG version (top) & the much lower priced Asus version (Bottom)?
Also, I have read that the watercooled version by BFG replaces the standard double slot 8800 GTX fan allowing room for another card so do the other cards take up 2 slots?
Sorry if it's a dumb question but can someone please explain?
Thanks again.
Thanks again.
