- 7 Aug 2012
Hi, going to be re-doing my loop tomorrow if my tubing arrives. Obviously I plan on running the loop for 12-24 hours to see if any leaks - however, my question relates to once system is fully up and running - is it a good idea to stress the system to get fluid warmed up as a further method of leak testing give that the o-rings might expand or contract with changing temperatures?
Or os ot safe to assume that if no leaks are found on initial testing that it is unlikely to start leaking with the system up and running? I will run it woth case side off anyway for a wee while.
Also, I am not using clamps on my 1/2" barbs with 7/16" ID. It takes quite a bit of force to get tubing alllied after heating up and removal seems near impossible without slicing the tube. But wondering if there are any horror stories?
Although I use a smaller tubing currently.
