Question on wireless card
18 Aug 2006
ChCh, NZ
Hey,
I always used to play with a wired connection on my main desktop PC. Recently I moved into a place where the internet is wireless rendering my desktop PC non-functional for the moment. Would one of those Wireless USB adapters work well enough or am I looking at buying a whole new wireless card?
both will work about the same and are around the same price, i would get the usb one as then you can have it on a usb extension cable and move it to find the strongest signal, if you do get internal then look for one that has removeble anteni, so you can use a extension and or a larger arial.
