I'm concerned my x1900xt is permanently running at 2d clock speeds (500/590). Playing games like BF2 I am seeing no real performance increase over my old x850xt pe and can't run at any higher settings than I did without jerking. My FPS is going between 25-70 all the time when I try to run everthing on high and it's just not smooth at all.
Other components are:
AMD 3200 64
2Gb RAM
When I alt tab out of BF2 (or any other game) and look at the speeds in ATI tool or ATI overdrive the speeds are the 2D ones. Is this because i've went back to desktop or is it stuck at 2D speeds?
AMD 3200 64
2Gb RAM
