Hi all,
I'm about to upgrade my rig. I've got an all aluminium Coolermaster case which I love and won't replace it. It can house 2x80mm at the front, an 80mm blowhole and a 120mm rear exhaust. Unfortunetly my current cooling solution is pretty crap and I'd like to upgrade it to something more active.
I've been reading about the Arctic PWM fans and from what I'm able to understand, it looks as though if I get 5 of the PWM models (inc the CPU) then my mobo should be able to control the fan speeds automatically based on temps. Am I correct? If so, I'm thinking about getting an ASUS P5K-E/WIFI-AP, Q6600+Arctic Cooling Freezer 7 Pro & a Corsair HX 520W PSU. Would this setup plus the addition of 3x80mm + 1x120mm PWM fans work ok? I don't really understand much about 3-wire vs 4-wire fans so any help or suggestions for a cool'n'quiet rig would be appreciated.
Matt.
Matt.
