As above
i purchased a pre built system from OC that is water cooled. The system is housed inside a bitfenix prodigy mini itx cube case, the plastic base/footing is a weak point and breaks easily. You guessed it mine has broken on one corner already, i now intend to replace this with some custom feet, which involves drilling 4 holes through the bottom of the case.
So the question is :- am i ok to turn the system on end to pop the holes in the case will water leak? i am guessing it will be ok after all it was delivered to me the wrong way up and it was all dry inside.
while i am here do water cooled systems need any kind of regular maintenance ie topping up if so how often?
thanks
thanks
