Hi,
I am in the process of getting parts for downsizing my current Phantek Enthoo Primo build to a smaller Core V21 build as i love the options and size of a smaller machine.
Currently in my Phantek i have a dual Bay resevoir combo D5 that takes up 2 5.25 front bays and was thinking of buying seperate resevoir and taking the pump out and fitting to the res but it seems a shame to waste a perfectly good pump res existing combo.
I was thinking of using some doublesided lock tape to fix the existing bay to the machine but then though about finding a 5.25 double bay bracket (which i cannot find)
Do you think its ok to do this or should i go for the whole seperate res, pump kits etc.
I'm not that fussed about how it all looks inside.
Cheers
Cheers
