Hi there i have a Coolermaster cosmos RC-1000 case and was wondering if anyone knows if it would be possible to mount a double radiator where the two exhaust fans are located on the top of the case? This would mean that the radiator would be mounted horizontal inside the case. Is it possible to mount a radiator this way? or do any of you know anyone who has done this? and would it be safe?
Any help or advice appreciated, Mark.
Check XS ^^
