Question regarding cpu blocks
6 Jan 2013
Rollergirl
Is the only difference between these two CPU blocks that one is completely see through, and the other not? Or, is there another difference in terms of quality etc?
http://www.overclockers.co.uk/showproduct.php?prodid=WC-357-EK
http://www.overclockers.co.uk/showproduct.php?prodid=WC-204-EK
Also, there's a lot of water cooling kit out of stock with OCUK right now. Is there an updated line of products due out that I'm not aware of? Don't want to buy something if a newer, better model is on the way!
yup the only difference is the top cover of the cpu block (if you get bored of the one you have you can buy different tops from EK) these are good blocks (have a copper one myself)
