- 31 May 2009
I currently have a home network issue which related to a WT610N and a WDTV live.
The folks at WDTv are currently investigating lots of network data I have collected for them, but they believe that my Linksys WRT610N is becoming the master browser on my home network, and is for some reason refusing to present any PC to the WDTV as a possible network share.
Network wise I have a vail homeserver a w7 pc a vista pc and the WDTv all hard wired into the router, and my VM modem into the router. All can access internet, and where shares are supposed to work between PC they appear to work, i can drag drop, read write files appropriately.
The WDTv can also access the internet, and can access the other PC from the point of 'media streaming' but thru the wdtv 'network share' option i can only see the wrt610n listed. Usually I should be able to browse up and down through the other PCs, none are listed.
If I swap the router to an old belkin I see network shares as I should.
I assume i have something fluffed in my settings, has anyone any idea what I need to change alter to allow access, and get things back the way they should be?
