Hi all, Iv just started my first ever water cooling project & need some help with regards to rad & fan placement.
I have Aqua-Computer Airplex XT 240 Rad that will be top mounted.
My question is where should I install the fans??
1)On top of the rad sucking air out of the case?
2)On top of the rad blowing air in to the case?
or
3)Under the rad blowing air out?
4)Under the rad sucking air in?
Now my limited understanding is that with option 1&3 the warm air that's in the case will pass through the rad limiting the cooling ability
With option 2&4 the cooler air from outside will pass through the rad resulting in better cooling, but it will also add more hot air into the case increasing temps.
Please could the pro water coolers please help me out
thanx in advance
or
thanx in advance
(in sig)
