Question regarding running Alphacool core distro's in series...
6 May 2025
Canada
Hey,
So as the title suggests, I'm starting a new build- and will be utilizing an external radiator setup.
This was originally going to consist of an Alphacool Monsta 360 Radiator, with a single Alphacool core distro 360 on 1 side and 3x120mm fans on the other.
After giving it a little thought I wanted to switch gears to an Alphacool Monsta 480 Radiator, with 2 Alphacool 240 distro's stacked on top of each other and ran in series, & 4x120mm fans on the other side.
Redundancy with 2 pumps being the primary concern, as well as having a fairly large loop planned within this build.
So my question being, is there anything I may be missing or should be wary of, running 2 distro's in this configuration?
Any help is appreciated!
Get a Mo-Ra external radiator instead if you want to run a external setup, way better cooling potential and simpler to put together,
Oh I completely agree.
However, It is also kind of an aesthetic choice as well as being functional as I'm incorporating soft sleeved tubing.
But theres also the cost factor
A mora costs a lot more than alphacool stuff
Have run pump res combos in series before
Never tried 2 distros
Though cant see any obvious reason why not
