Question regarding S works enduro shock replacement
6 Feb 2004
Wiltshire
Quick question or two.
Toying with the idea of changing my DHX5.0 with a Fox RP2 or an RP23.
Is this possible? as my DHX is 150mm.
a. can you get a RP2 / RP23 at 150mm
b. If not then can the Frame do less than 150mm
c. will this change the Geometry?
thanks
a: yes, look at the eye to eye length and stroke of the shock
b: yes
c: yes, it will slacken it.
d: Why do you want to change shock?
