Question regarding space in Antec nine hundred...
28 Dec 2005
Hi guys
After reading the specs, looking at pictures, and reading reviews,I'm a little confused regarding space in this case.
I understand that the 8800GTX will fit in there (though you'd need to lose one HD Cage if I understand correctly), so that means you can fit up to three hard drives, right? But what about the front...there are those two massive fans which, presumably, means you can't put a cd/dvd drive in there...would there be space for 2 dvd drives, a memory card reader and a floppy drive? Or if not, how about just the 2 dvd drives and memory card reader?
The 900 has 2 hard drive cages and these are removeable. The fans are attatched to the cages. I have a GTS in my case and didnt need to take out the cage. I dunno how big the GTX's are. The only thing that gets in the way are the power connectors for the drives / card. Heres a pic just for you.
It only really takes up space for, say 1 or 2 hard drives (depends on your setup / mobo) and there is still room for another 4 in the cages. I have 2 x DVD-rw drives in the top and 1x card reader. No need whatsoever for floppys these days. I have a USB one if i ever need to.
EDIT: http://forums.overclockers.co.uk/showthread.php?t=17700204 theres some other pics, although i have rewired and have an 8800, but you can clearly see the front of the case setup.
