Question regarding USB and Analog headsets.
3 Apr 2012
Basically, my friend is trying to decide between some new headets.
What I would like to know, is that if a headset uses purely usb for its connection - can it use a sound card? does it need to use a sound card?
Thanks
Well how are you going to plug your USB headset into a soundcard ;)
The quality won't be as good and the flexibility limited to the USB headset chip which could be a good or bad thing depending on how well the headset and chipset are engineered in harmony.
USB = Quick easy portable headset
Analog = Quick easy portable headset
OK I was going to list the pros and cons but analog is just as easily inserted into a PCs onboard/soundcard and it's portable as most sources have these and it's quick it should work instantly.
