Question regarding WHEA Errors
25 Jul 2012
Hi,
Just a quicky about those troublesome errors in the event log.
I currently have my i5-3750k setup as below.
Intel i5-3570K @ 4.5Ghz
Gigabyte Z77-D3H
Kingston HyperX Genesis Grey 8GB PC3-12800C9
Close Ratio: 45
XMP: Profile1
PWM Phase Control: eXm Perf
Vcore Loadline Calibration: Medium
CPU Vcore: Normal
DVID: +0.080
Whilst I seem to have stability (no BSOD, App crashes etc), I sometimes get these WHEA errors appearing (mainly in FSX).
A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: Corrected Machine Check
Error Type: Internal parity error
Processor ID: 2
I have upped my DVID a couple of notches, but i'm wondering if its worth is as the PC isn't crashing?
Ideally you don't want errors as its making the system inefficient. A couple of notches on Vcore should address it though so I would not worry.
