Hi, I was hoping someone could advice me on a few things. I have recently upgraded to 1440p 144hz monitor using x2 GTX 780 TI's overclocked to 1228mhz stable. I have an intel i5 3570k which currently is overclocked to 4.2ghz. My fps are awesome in most games especially bf4 but my CPU does bottleneck the GPU s at times so I ddecided to try overclock to 4.5-6ghz. I have done a lot of reading and have had good results in the past with previous CPU but with this one no hope over 4.2. I have tried fine tuning and volts as high as 1.36v and bsod 30 secs into intel burn. But mostly the system would not go past the BIOS and even completely crashing needing the BIOS reset. After about 20-30 FAILS Of different settings and configuration I was beat and gave up!:'(
It really put me in a ****** mood as had good luck with setting up and overclocking the GPU s and now feel let down by the cpu. I put my system through HELL trying to get an extra 200-300mhz and worry now that it's stressed the rest of my system out with all the BSOD and hard resets I've done. All seams fine back at 4.2ghz now.
What kind of affects can doing as stated above do to a system? Has anyone else had the same trouble and gone to the extremes I have to get a decent stable overclock (many attempt s trying with lots of crashes hard resets)?
As for the CPU i don't know what to do in terms of of leaving it or complete upgrade to gen6. On the whole the 3570k holds up well just at times I see the fps drop hard with the CPU maxed but the GPU at 60-70%. Would a 6600k make all be difference?
Your experiences and knowledge would be most appreciated.
Thanks
Jay
Thanks
Jay
