Not really, you could use Heavy Water, Dideuterium monoxide, if you wanted and it'd still put the fire out. It all depends on what's ablaze though really.
I'm sure there's probably a balancing point somewhere.
It would depend entirely on:
Temperature of hot water (i.e. is it close to boiling point or near freezing?)
Quantity of water
Dispersion of the water as its sprayed or poured
Intensity of the fire
I'm sure there's a point at which the water *could* be near boiling point, lacking enough volume, far too dispersed, and just turned into steam or vapour.
I could be completely wrong though and everything above is rubbish.
I would imagine cold water due to it needing energy to reach its specific heat capacity and it's high latent heat of vapourisation (Nerd words F.T.W)which it could take from the fire's 'energy'
Liquid *nitrogen* would be better
You can tell who passed their year nine science SATslol
You can tell who does a science degree or are science-y mindedlol
Correct me if i'm wrong but fire does not need heat, it generates heat. I.e. you can light a fire in the depths of space al long as you have oxygen.Fire needs three things: Heat, Oxygen, Fuel.
I got Level 6 for year 9 SATs if I remember, this was about 5 years ago!
Thats out of 8 levels
I got 7 6 7. Bit above average iirc. 6 in English
You can put your hand in fire without being burnt depending on the source, cold water is better as it takes more energy to evaporate it.
Oh right I see what you mean... Sorry, as usual I'm crap at readingFire needs heat to sustain itself, if you cool it it stops.
But I think you are right in the fact that you don't need heat to start it, just some kind of spark/reaction.
