Questions about Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU (C
21 Jun 2004
Berkshire
Hi,
Building a new machine for a mate and wondering if this case comes with any fans, or will I need to buy 2x 120mm fans?
Case: Antec SLK3800BUK Black Quiet Midi Tower Case - 400W SmartPower PSU (CA-048-AN)
Thanks
It has one tri-cool 120mm fan at the back with three speed settings (low-mid-high, or "quiet", "ok", "noisy"). There is space up front for another 120mm fan, which is not included. Whether you need a front fan or not depends on whether you're putting in some hot components or not - the case is supposedly good on airflow. There's a review of it on www.silentpcreview.com (the version without the PSU is SLK 3000B).
