So we just had a study area built into our dining area, and me and the missus both have large PCs, housed in Gigabyte Aurora 3Ds, and they're just too big for the study area we've had built.
With this in mind, I did some checking, and SFF would be the ideal solution, in fact, the Shuttle XPC SX38P2 Pro is really the perfect size.
Now, I have perfectly good bits in my current PCs, and basically want to know if I would be able to fit these into that Shuttle?
The bits I have are:
Processor Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz, 2400 Mhz
OS Microsoft® Windows Vista™ Home Premium
Graphics NVIDIA GeForce 8800 GTS
DVDRW Optiarc DVD RW AD-5170A ATA Device
HDD Seagate 320gig X2 in a RAID0 config
Wireless Netgear RangeMax N PCI Card
So, I'd like to not have to replace any of them bits if possible, to reuse them.
Would they fit in ok?
Will I be able to just plug everything into a Shuttle case, switch on, and do whatever, or, will I have to format the drives and start from new?
Do I literally just unplug my CPU and lob it into the Shuttle, and does the shuttle have its own CPU cooling system or am I going to need to buy something?
Will my windows licence work ok? I'm not going to try using the same licence twice.
The GFX card seems quite thick to me, and is quite long too, is that normal and will that be ok? My graphics card is HERE
Also, I was thinking of ordering myself OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 and then putting four 1GB DDR PC2-5200 sticks that we currently have into my missus's. Will this all work too?
Other info that might be helpful:
We surf the internet, email etc. We play WoW. Thats it pretty much. No FPSs etc.
I wont be planning on SLiing up, am happy with the cards as they are atm, but if there was an option for that, what is it? No need for lots of room inside, this config will do me fine for a while yet.
So, any comments / advice welcome!
